Snapshots [Tab 19]
Note: On Element 2 and Element Classic consoles, {Snapshot} is a softkey.
When snapshots are recorded, you can view them in the snapshot list. To view the list:
- Press [Snapshot] [Snapshot].
- Press [Tab] [1] [9].
- Navigate to Browser > Record Target Lists > Snapshots.
- Select the Pop-up Snapshot Browser from the top-right menu icons.
Snapshots can be recalled in the following ways:
- From the keypad/ command line - [Snapshot] [5] [Enter].
- From cues using the execute list.
- From a recorded macro instruction.
- From the direct selects - {Snapshot 4}.
Since snapshots can be recalled from any device (except RFRs) on the Eos Family network, snapshots may be affected by the type of device they are recalled on. If the recalling device does not have the same physical layout or has other limitations that differ from the recording device, Eos will map the snapshot to the best of its ability.
In a system with multiple users, it is recommended that you allot discrete snapshot numbers for each user. Since snapshots are global and can be recorded/ recalled from most devices, assigning numbers for each user will ensure their snapshots are stored and edited properly for their device.
